Fuel Filter install on RTV1100
cowrider
I installed a bowl type filter on the RTV since I didn't care for the in-line filter. I made the bracket from thin angle rounding off the corners. I used a 6A320-58862 filter. I mounted it to the rear tapped hole on the frame. The filter has a third hose fitting in the center which I ran up to the top of the fuel tank, there is a capped off fitting to which I attached it to.
Thanks! That is a spin on replaceable filter on the housing? If so, that looks like what I want to put under my BX24 as a primary filter. Off to snoop for one online.
