joncowcare
Hi all,
These new Plasma cutters are incredible to use and watch in action.
They cut through 10mm plate like a knife through butter !
However, what happens when you need to do a job outside or in the field ?
Call for the gas bottles is the cry ! [Oxy-acetylene or Unsaturated hydrocarbon if you're a boffin]
Once you've lugged the heavy things to the job what pressures do you use for cutting ?
I always have a 5/45 mix and was wondering what pressures you all prefer ?
This is usually fine for anything up to 10mm plate I find although for box I reduce the mix down to 4/40.
Cheers !
Jon
Cheers !
Jon
