Gauges sweeping
swalley
I have a 2015 NX4510 the gauges go to sweeping back and forth and runs bad for a minute or 2 then straightens up runs fine for a while then does it again when it does this all lights on dash come on help please
If it's running bad, I could see the sweeping.
Are the gauges fine when the tractor runs fine?
I'd start by addressing the running bad situation.
bczoom the tractor runs like a champ until it starts feeling like a small miss then starts the sweeping and dash lights come on like you see when first starting does that make sense sir
Just guessing here, but "running bad" and gauges acting up at the same time. I have no specifics for what the problem might be, but with a common rail fuel system I'm sure steady system voltage is required. I'm betting you have a power connection or ground issue somewhere.
Thanks Fedup that’s what I’m thinking too but having trouble finding a wiring diagram to find all grounds I’ll just start at one end a go from there.
Still having trouble with gauges sweeping and running bad I tried to upload a video but it wouldn’t let me tractor will start up and run fine then about 10 minutes or warms up good it starts this I’m scared to run it long when it’s starts because it clatters bad for a a minute or so I’m afraid it will break something
