[quote user="TWO GUNS"] I was thinking about you could install a plate on the inside or should I say, the bottom of the roof, then running your mounting bolts threw it and into the mounting plate on the GoLight.( Something like a sandwich thing on the roof )That would support the light really great with no play init. The mounting plate that comes with the light, installs really easy, then, after you have it in place, the light slides and locks onto the plate, with a set bolt or screw in the back of the light, the light is solid as a rock once it is locked on the mounting plate. For the bottom plate, I would go to your local sign shop, and purchase a piece of 6" or 7" square or whatever need be, ( get them to corner round the corners at a 1" radius ) .080 aluminum sign blank, should cost you about $8 -$12 for the plate, it would always be rust free, easy drilling, and I think your top is black, just lightly ruff up the baked on enamel on the aluminum plate, and paint it with Black KRYLON ENAMEL paint. It WILL come out perfect.[/quote]</P>
</P>
Two Guns</P>
Great advice. Thanks... [
]</P>
Based on your experience with this product:</P>
Can the controller be easily mounted on the dash?</P>
Will the light work for additional lighting forward and rear (meaning I don't need to add additional lights)?</P>
With a Plastic Top and no liner what would be the best way to run the wires?</P>
Have you run wires in the ROPS?</P>
Thanks</P>
Doug</P>
