GT235 Rocker Cover Gasket
trafficscout
I've posted here before - probably right below this post :) and every time you guys have helped.
I need to change the Gasket on the Rocker Cover.
What is the best way to do it.
Only 2 screws but i'm not sure if I should just unscrew it or do i need to drain it first, etc. Thanks
If the gasket needs changing- it may have let "water" etc get in. if that's the case, I would change it. Pictures?? bordercollie
