Hissing sound when driving around
extrafu
Hi,
I have a almost brand new 1100XC with less than 50 hours on it. When I start it and drive around when it's "cold", it doesn't make any hissing sound. After a few minutes a few minutes of running, it starts doing this extremely annoying hissing sound.
I took a video a few minutes ago:
When I stop moving, it stops. Sometimes it doesn't do it, like when going downhill, but when I go uphill or on flat grounds, it's just insane.
What can do that and how can I fix this?
Thanks!
Welcome to net tractor talk. We have the best bunch of RTV gurus around. I don't recall seeing this issue before but someone with the know how will take a shot tomorrow I bet.
i would check for exhaust leaks??? or a plugged restricted muffler spark arrestor? as always-----check the fluid level in the tank under the seat and in the hst? always use sudt oil.
extrafu
@ItBmine Thanks for your response. I was just about to write an update and suggest that. I've checked the fluid level, all fine. The exhaust, all fine. Could it be the belt being a bit dirty? I've used the RTV with a lot of dust around (carrying dried top soil, etc.).
If so, what's the best way to clean things up? Water and light soap?
Thanks!
ItBmine
I would check adjustment tension and condition. It could be dirty or even wore? Back in the old days I remember people rubbing hand soap on belts. You can also buy spray on belt dressing too if that is the problem.
Try the simple cheap things before you panic!
good to hear all fluids are full and in spec. what about the coolant? could there be a steam leak? another thing to check might be for a kinked or pinched line causing a restriction? feel the lines for hot spots after running. 50 hours? what year is this machine? still under warranty?
Is the fan belt snug ? I also has a heat deflector on the muffler making a squeaky type noise . ( it had a crack in it but I had a lot of hours- for sure ) .
extrafu
Sorry if it took me a couple of days to check things out.
Yes the belt seems snug but there is a fair amount of dust around the pulleys. The RTV is a 2020 and the warranty ended about 3 months ago.
Should I spray some soapy water on the belt and pulleys to clean them up while the engine runs? It's clearly a mess to try to reach all pulleys.
Thanks,
Myself, I use a LIGHT coat of Fluid Film as a belt dressing. Spray it into the V of the belt and it'll work its way around to the pulleys.
ncridgerunner
I once had a belt pully bearing that was wearing and made a sound like that on a tractor. A little lubrication would temporarily stop the noise but I had to replace the pully to fix it. I'm sure you know to be careful using lube near the belts as that can cause more noise.
I would think your machine is too new for this to happen but stranger things have happened.
@extrafu - Yes, that's the product I use. Looks like you pay a lot more for it. Last time I bought, it was $8-9 per can.
extrafu
So I bought a can of Fluid Film and did spray it on the belt when the engine was running. Went for a quick drive - at 50% throttle, no hissing sound. At full throttle, continuous hissing sound. My machine doesn't even have 50 hours - it has 25 hours and less than 100km :-/
