Hydraulic fluid leaking
joshdk60hst
New to the forums. Run into a problem beyond my usual scope. Got a 2022 dk60 hst and it just started leaking a lot of hydraulic fluid.from underneath.
I started it and let.it run for 20min before taking a run at snowblowing my yard and noticed a steady leak when I made my first pass and then a larger puddle from where I had had it sitting warming up prior.
I just had this thing serviced at the dealer for its 250hrs maintenance . Currently at 274hrs.
Any ideas based on location
If that's a transmission weep hole it's an awfully big one, and if that's where the oil appears to be coming from you probably have a tractor split in your near future. There must be something on the front side of the transmission leaking into the clutch housing area.
