A friend has this old 600 Mule he uses almost daily to haul hay bales out to feed horses. It has recently developed a "no start" issue that might (or might not) be related to the neutral switch. No real proof of that yet. Could be a number of things I guess, but I thought that would be a good place to begin with. I was out there today and it did nothing when the key was turned to start. After he hit it with a leaf blower, knocked of a few pounds of dust, cobwebs, and hay scraps off the engine/transmission it started right up. Without touching anything. I may have wiggled a few wires a bit just looking to see what wires went where, but nothing was really disturbed. It started first time every time for at least a dozen tries. He did mention that it had done the "no start" thing a time or two over the past few months and once moving the shift lever got it cranking again.
Question for today is where did they put the neutral switch? Would it be somewhere around the shift linkage or maybe on the transmission? I noticed a sensor (or possibly a switch) on the transmission threaded into the case in the neighborhood of the vertical shaft the shift cable attaches to. It's a single wire item, so if that's the switch it must be a ground for a relay coil I would assume. That would mean it has a start relay somewhere?
Anyone have any experience on these machines they might care to share?
