ChrisCrawford
My KL5510 recently sprung a transmission oil leak. After a great deal of effort, we have zeroed in on the source of the problem. I attach a photo I got of the problem. It shows the rubber seal boot where the gearshift shaft enters the transmission. There's a hose clamp holding the base of the seal to the transmission. This strikes me as peculiar; hose clamps on seals like this can bite into the boot at the edge and open up a leak. Moreover, I wouldn't expect Kioti to use a hose clamp there. I suspect that this was a repair done by the previous owner that is now causing the leak. Or it may be due to some other cause; there appears to be a crack in the boot at the fold immediately above the hose clamp.
That area is extremely difficult to access; it is immediately underneath the foot deck plate. We tried to remove the foot deck plate immediately above this location, but are prevented from sliding it by the bolts holding two thick rubber shock absorbers that support the foot deck plate. I could just barely wipe parts of the area clean with my fingertips. The shop manual provides no guidance on how to remove the foot deck plate. I did find one reference that suggested that, after removing all impediments, I slide the foot deck plate rearwards and tilt it up. It appears that Kioti has carefully placed a variety of bolts to insure that this is impossible. After trying everything I could, I had to give up.
So, what can I do? My previous experience with tractors was with a 1953 Ferguson TO-30, which was, shall we say, considerably simpler than this machine. I'm in much deeper water now, and I am struggling to keep from sinking. Any ideas?
