Kubota plow lift need help in a bind
Mark.Sibole
I have the curtis plow with the linear actuator for the lift and mine just took a dump on me.Anyone here know where a replacement can be had or have one you arnt using you would be willing to part with????
Im in dire straights without my plow in the winter.
Mark,
Have you put power directly to actuator to confirm it's not a wiring issue?
There is a relay close to the battery (at least on mine that's where it is.)
Sometimes you can test and read voltage but have system not carrying enough amps to operate.
Mark,
Yes I just had it all apart.It was a broken wire right where the wire went into the actuater.While apart I noticed the brushes are also on their last leg and not sure if i can find a replacement brush.For now it is working thank god because were under a winter storm 8 to 12 inches.But i still need to find a replacement as i dont know how much more ill get out of the brushes but like i said for now its working.
Mark,
I removed mine and put a hydraulic one on a couple of years ago. If you want I can see if I can find it. I'm pretty sure it's in the garage.
Randy
Mark,
Randy
Thanks Randy Id really appreciate it.IM sure it has low hours on it unlike mine.Let me know.Ill send you a PM with my number so you can call me if you find it. YOU ROCK!!!!!!!!!!!!!!!!!!
Randy is my hero.He saved my arse.Ill have a new actuater here in a few days.
Thanks again Randy, you dont know how much I appreciate it
Regards
Mark, you messaged me on TBN. It looks like you are set, but I still have mine as well if you should need it.
Thanks I was in a bind and sent multiple messages in hopes someone had 1.To be honest I didnt think anyone would have it.Ill keep you in mind if i need another one.I very much appreciate it.As always if ya'all need anything im always here.I may live here more than Bordercollie but i just dont say a lot and by the time i see a thread needing help MIss Bordercollie has it covered.
You all are the best.
Regards
PS you all Rock here and TBN...:applause:
It makes a difference when the community helps each other. You can't ask for anymore than what happened on this thread.
