thank you sir. I appreciate your help.Let's hope Arthuritis shows up, he has an older 1100 and he is very knowledgeable on these machines. I try to help out where I can but this one is above my pay grade.
Thanks I think I did. Lol. No not doing both at the same time. Definitely seems like hydraulic system is starving somewhere.Well, don't sound as if you did anything wrong doing the service Mister T. You got both oil resevoirs.
You're not trying to steer and dump at same time are you? They seem to fight each other for fluid when you do that.
Hope it's something simple. Good luck.
there is where your problem is then. take a look at that valve and make sure it isn't stuck . feel it for heathydraulic noise or growl comes from area under dump lever.
thanks so much for the input. I’ll keep plugging along.i doubt that your pump is bad. sounds like you have a restriction of some sort. a damaged hose could be coming apart internally or the pinched hose? could be a piece of debris in the lift valve causing a restriction. sometimes the friction will cause heat in that area where the restriction is???
Sir, were you ever able to determine the cause of your issue? I am currently experiencing the same issue. Thank youSeems like a hose running under skid plate ( by engine oil drain plug) from right to left side of motor has a flat spot in it. How common is it for pump to go bad. Only 322 hrs on machine.
