Kubota RTV 900 2006 Transmission Problem
Mcquaide
Hi! I was wondering if anyone had some potential solutions for an issue with my kubota RTV 900 2006 transmission. The kubota will not move in any range forward or reverse unless the differential lock is held. I pulled the rear axles and the splines on the axle are good. The inner splines on the transmission look good. It seems like it only will drive on the right side when the differential lock is down. I checked the transmission cables and they are engaging. I didn't see any posts about this problem so was wondering if anyone had any thoughts.
sounds like your differential is blown. i think you can remove the differential out of the side without removing the transmission
