Kubota RTV Speed modifcations?
  • Start date Start date
G
Has anyone figured out away to get theses things to go a little faster? I have already gone through and adjusted the throttle cables and the speed control plate and stuff and now i can go about 31 mph but i was just wondered if it was possible to get another 5 or so mph's out of it?</P>
beyond what you've done...? Maybe bigger tires. Sounds like you've covered the mechanical stuff. </P>
</P>
As noted, tires are about it.
If you want to go faster, I'd propose you buy another UTV for speed (Rhino or Prowler). Keep the RTV for slower things or work.
[quote user="Anonymous"]
I have already gone through and adjusted the throttle cables and the speed control plate and stuff [/quote]</P>
What is the speed control plate. and how do I adjust it.I'd like to go 31 mph.</P>
Try putting Power Service diesel additive into the fuel. It seems to have helped
mine out. Run's a little quieter and it's got more pep. You can get it at Walmart
and alot of other automotive store's(WallyWorld's cheapest).Get the grey bottle
of P/S it has a higher cetane rating than the white bottle. Yes there is two different
bottles of this same product, the white bottle has anti gell formula for cold weather
with a slightly lower cetane rating. If you think about it while you are there pic up
some marvel mystery oil for and add a little of that to the fuel also.I have been doing
this for some time with no ill effects(Truck & RTV) P.S increases fuel mileage also
not that the RTV need's it.
I just bought a new rtv could you fill me in on how to adjust the cables and plates on mine to get it to top speed.
