kubota rtv900g wont move
botaman2013
I had gotten a Kubota rtv900 from my company for free and got it running now having problems getting it moving the case in the back wasn't fully bolted to it so im thinking something is missing but I had taken the brake lines off thinking they were frozen and I spun the rear axle while in all gears and both wheels were moving as I turned it so then I started it and put it in drive nothing happens.
any suggestions?
I also have read about pressurizing the transmission how would I go about doing that?
Is the shift lever firm or floppy? It could be that the shift fork is one of the problems. If forced, they will cause grief by breaking.. There are a number of threads on here about that. Also other possibilities but the fork comes to mind. How does the fluid look and do you know if has it been changed recently along with the filters? Others will chime in. bordercollie
