walleyeguy13
I know next to nothing about tractor engines so am looking for thoughts from the experts. We have a Massey Ferguson 180 with the Perkins diesel that came with a property we purchased. Started and ran just fine last season. Started and ran fine for several hours yesterday and today... until it didn't!
We were clearing some trails in the woods all morning and brought the tractor up to the cabin to hook up a box scraper. While backing up, the tractor just quit and we have not been able to get it restarted. What we have done:
Checked all along the line to make sure fuel is present and pumping... from tank to pump, fuel getting a strong stream to the first fuel filter. Bled both filters, fuel is flowing out there. Drained the sediment bowl under the first filter. Opened up both bleeders on the injector pump... strong stream out those when engine is cranked. Loosened the connectors to the fuel injectors and verified fuel is running out when engine is cranked... you can see short quick squirts of fuel. So it seems we have fuel flow without air bubbles present.
The engine cranks fine, and fires when starter fluid is sprayed into the port above the alternator... just no apparent fuel flow.
Taking a look at the fuel... it looks pretty cloudy so we are wondering if this might be the culprit. It is from last season and has not been treated. Not sure how it ran for a few hours beforehand, but at this point we are looking to start from scratch. So our plan is to drain all the old fuel, change the filters and see what happens next.
Should we be looking at the injectors themselves?
Appreciate any thoughts/feedback.
