My Mahindra 9110S has a Hydraulic Clutch Low Pressure/Strainer Clogging Warning Lamp activated - Need help locating sensor
sawyer2678
While brush cutting, my tractor started alarming with the gear symbol and the two arrows pointing at the gear indicating a "Hydraulic Clutch Low Pressure/Strainer Clogging" alarm condition. I shut the tractor off and checked for leaks or loose wires underneath the tractor but none were found. I need to know where the sensor is located for this alarm condition, if any of ya'll know I sure would appreciate the info. I haven't been able to find it in an online parts diagram or in my service manual. I restarted the tractor and the alarm immediately returned. I moved the tractor about 50 feet to a clearing and shut it off and haven't restarted it again. The tractor also displayed ERROR code: 2302, which means there's a "Short or Connecting Fault at the Strainer".
Problems solved... found the sensor behind the battery box on the right side. One of the two connectors had come off the sensor. Reconnected it and no more problems.
