MY RTV
Nice looking machine!!!
I'd sure appreciate more pics and info on that seat you put in the box.
THE REAR SEAT IS A DELUXE RUMBLE SEAT PURCHASE FROM</P>
ALL TERRAIN ONLINE ,$299.99, THEY HAVE ONE A LITTLE</P>
CHEAPER, BOLTS TO THE BED, BUT IT IS DETACHABLE JUST PULL TWO</P>
PINS ON EACH SIDE& THE SEAT COME OFF,WEB SITE IS ALLTERRAINONLINE.COM</P>
THE DELUXE RUMBLE SEAT</P>
MODEL # UVDRS200BL</P>
THANKS</P>
FDHARLEY</P>
THE FLOOR PLATE IS A ALUMINUM DIAMOND PLATE FLOOR PLATE</P>
RTV SERIES MODEL KFM FROM( TELLICO 4 X4 .COM )</P>
PHONE 800-566-3646 $90.95 PLUS SHIPPING </P>
JUST BOLT IT DOWN WITH SELF TAPPING SCREW</P>
</P>
ALSO BELOW PICTURE IS A WARN RT 40 WINCH 4000</P>
FROM ALL TERRAINONLINE.COM</P>
PHONE 903-896-7565</P>
WARN RT 40 $449.00</P>
KUBOTA WINCH MOUNT-INSIDE MOUNT $63.97</P>
</P>
THANK</P>
FDHARLEY</P>
</P>
Nice looking unit! Can you tell me about the glass rear sliding window that you have installed. Is it the option sold by Essex Mfg? Thanks.
THAT RIGHT, THEY ALSO SELL A PANEL TO FILL THE BOTTOM</P>
OPENING BETWEEN THE BOTTOM OF GLASS AND PANEL THAT ON THE</P>
RVT ,I MADE THE SIDE PANEL ONES</P>
</P>
THANKS</P>
FDHARLEY</P>
I WILL POST ALL THE ABOVE ITEMS ON KUBOTA RTV PARTS/ACCESSORIES LIST </P>
[quote user="fdharley"]
</P>
THANKS</P>
FDHARLEY</P>
[/quote]</P>
I'm going to have to install that small piece that goes under the bottom, didn't know it existed until after the unit arrived ~~ Haven't had our back slider but about 2 weeks.... Wish I had it back during hunting season....</P>
<p class="MsoNormal">I have a few questions regarding the usability of the glass
back sliding window. First of all, I notice that the rear protector
screen ( metal ) is on the outside of the window. How do you clean the
back side of the window if it gets dirty? Does the sliding glass tilt out
somehow for easy cleaning? Also, does the window cause any
additional noise ( rattle or squeaks )? Thanks for your input.</p>
I HAVE NOT HEAR ON ANY RATTLE OR SQUEAKS FROM THE WINDOW</P>
ON MIND THERE IS ABOUT A 2'' BETWEEN THE GLASS AND THE PROTECTOR</P>
THE GLASS IS STATIONARY JUST SIDES FROM SIDE TO SIDE DOES NOT TILT</P>
TO CLEAN I WILL SPRAY WITH A WATER HOSE AND SPRAY WITH WINDEX</P>
THE BOLTS THAT COME WITH THE KIT ARE ABOUT 2'' LONGER YOU</P>
COULD PUT A SPACER ON THE BOLT OR GET LONGER BOLT WITH SPACER</P>
TO GET THE PROTECTOR SCREEN WHERE YOU DESIRE TO CLEAN THE GLASS</P>
HOPE THIS HELPS</P>
FD</P>
I JUST INSTALLED IT LAST WEEK, AND IT HAS BEEN RAINING ALOT</P>
IT NOT AIR TIGHT LIKE THE ONESTHAT COMES IN PICK-UP TRUCK</P>
BUT WILL KEEP RAIN AND WIND OFF YOU, NOW DUST IT SHOULD WORK</P>
NOT SURE HAVE NOT DROVE ON A DUSTY ROAD YET, BUT IT WILL SURLEY</P>
HELP, OPEN THE WEB SITE (ESSEX MANUFACTURING INC)</P>
FD</P>
On the Back Slider Window,</P>
No Squeeks or rattles on mine, I did put longer bolts and spacers . Going to come off with my lock-nuts and install some wing-nuts >>>>> should of done that at first, but , learn as we go ~~~~</P>
Cleaning will be no problem ... This accessory is going to be a big plus for me [:D]</P>
I couldn't wait any longer, so I order a rear slider after seeing this post. The problem that I have, is I currently have a factory installed Curtis Cab and the rear lower cab frame that is located under the slider prevents me from installing the optional filler panel that is offered by Essex. I previously had the snap-on vinyl rear cover, but it was hard to see out when the sun hit it. The vinyl cover did offer 100% dust, wind and rain protection, but the new slider doesn't work well with the Curtis Cab if you want to be fully sealed from side-to-side and top-to-bottom.</P>
ST</P>
Having the 900 with no cab, that back-slider was a big plus for us. All we wanted to help keep the cold air and rain from blowing in on the back of your neck. Plus, of course, it helps so much on any back draft noise ..... Didn't know till after I received the back-slider, that they had a filler panel. </P>
<FONT face=Arial size=2> </FONT><FONT face=JohnHancock color=#ff0000 size=5>Two Guns </FONT></P>
