NEW OWNER
tep
I am a new owner and was wanting to know about the linkage adjustment for a little more speed that I have read about on the forums. I also have an extra set of struts and heavy duty springs if anyone is looking for a set. Great maching! </P>
I'm taken' that you are the new owner of a RTV. That's Great !!!!!Your world has just changed for the better ****** Must have a good dealer, to throw in a extra set of struts & heavy duty springs.
I don't think the dealer knew that you needed heavy spring OR heavy struts, so he put both in with the deal. now I have original struts with regular springs and a set of heavy springs to go with them. I put the hard top and glass windshield on with the hard back and soft doors. Today I started mounting my winch. Had to camo the top it only comes in orange and mine is the recreation model. Went to camoclad.com and got some camo cover to match.</P>
Just curious, what did the unit come with from the factory , or did it come with heavy duty & you went back to regular, or did it have regular, & he just threw in the heavy duty for you to install ? I really don't understand >>>>>> Do you need the heavy duty springs ?</P>
When you install the camo-clad, clean the top good with windex, then right before application of the camo, wipe it down with denatured alcohol, and let it dry, then apply. Your application of the clad with adhesive alot better. If you do it the wet method, go by a sign shop and let them sell you some application fluid, it contains a adhesive setter & alcohol in it, once you get it applied and set, squeegie it, it will come out so much better, and stay on longer >>>>> just a thought !!! Or, just bring the top & clad to the sign shop & let them install it, trust me,if you do this everyday like they do, it will come out so much better & look much more professional !!!!</P>
<DIV><FONT face=Arial size=2></FONT></DIV>
<DIV><FONT face=Arial size=2></FONT></DIV></FONT></DIV>
It came with regular springs and struts. When you put the cab and glass windshield and winch Kubota recomends the heavy duty struts or springs. The dealer sent both. Now I have regular struts with regular springs and an extra set of heavyduty springs that will go on the regular struts. If you know anyone interested I would sell them.
