For the last 2 days now I have noticed that the RTV will not shift into high gear when the accelerator gets mashed to the floor board. Usually I have to ease off the pedal when I go up our secondary driveway. I've played with the pedal to see if I can feel a shift from high to low gear while driving, but I always find that the speed stays the same. The engine doesn't seem to lug down anymore.
I've been hauling some landscaping rocks all around the acreage, and I've put on about 30 miles with a heavy load in the bed. It's dusty out here and I am hoping that a change of fluids and filters will clear this up. The RTV has 153 hours on the meter, and the 50 hr fluid change was done 103 hrs ago. The manual states that the hydraulic fluid changes are due at every 200 hrs intervals.
Is there a adjustable lever that I can tighten or loosen, depending on which way it has to go, that will turn on the auxiliary pump sooner? The manual doesn't claim that there is an adjustment.
All other PM has been done, like greasing and lubing.
Any advice?
Thanks,
NVBadBoy
Any advice?
Thanks,
NVBadBoy
