Peanuts Stick Stoppers
Doggonedawg
I'm trying to verify fit if the stick stoppers on a 500. I know I have the same
3 15/16" bolt spacing on the lower A arm as the 900s. Could someone please measure and provide me with the actual dimensions of the guards length and width wise so I can see if there are any obstructions that need attention? Thanks to all in advance.
I did NOT I repeat DID NOT measure but the part numbers on the lower arm is the same as the 900 along with most other parts. hope this helps
Doggonedawd:
Here are a few photos of the stickstoppers on my 1100.
bottom of stick stopper
there is also this triangled piece that fits on the bottom of the A arm. It is bent 90 degree up on each side of the A arm. The bolt you see in the middle of the bottom of this bent triangle shaped piece also goes through a much smaller triangle piece on top of the A arm and sandwiches the two pieces together.
