Yesterday while cleaning out my unfinished shop, I elected to pull my inoperable JD 2640 tractor from the shop to the barn. Tractor was previously used to drive an irrigation pump. I'd let it run for about 3 hours when I felt the need to check on the tractor. When I arrived, the tractor had just shut down and locked up after developiing an engine oil leak. Sad day, anyway that's why the tractor is inoperable. The shop manual states that the tractor's shipping weight is 5100 lbs. You guessed it! Yep, hooked the RTV 900 XT to it and drug the tractor about 150 yards to the barn. Pretty much just drove as slow as the RTV would go in low range. It frankly didn't feel like anything was hooked to the RTV. The path to the barn was flat, yet this is still an impressive feat for the RTV.
I guess I'll have to see if it will pull the JD 6410. With front end loader, that tractor is over 14,000 lbs. Somehow I bet the little RTV will do it, but I believe I'll forego this to avoid possible damage.
Man I do like this RTV!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
