Rear Tire Mud Flaps
GFC
I need to replace the front and rear mud flaps on the rear tires on my 2008 RTV900. I am looking for a set of aftermarket flaps that are more durable than the ones Kubota put on my RTV900 at the factory. Any suggestions and sources would be appreciated.
GFC, Several months ago, several of us discussed the same thing on our 900's as well. I had considered adding some angle iron the bottom of the cargo underside and hanging a flap from that for the rear. It would sure help keep the mud off of the tail lights too. Something similar should work in front too.. but haven't tried it yet.. I think an 1100 is different in that the fenders are not part of the cargo bed. bordercollie
edit: http://www.nettractortalk.com/forums/showthread.php?t=15117&highlight=flap
Tractor Supply sells rubber material that can be used as a flap.
Also, you could pick up ONE mud flap, they make them stiff and flexable, your choice. Cut desired shape and install ....
just a brain fart ..........
......... two guns
