Rear u joint and axle shaft help
Mvideo
Need help with replacing rear u joints in my 2006 RTV 900 I just picked. I have read a lot about this on the forum and even watched a few you tube videos. Anybody have the a step by step procedure for removing and replacing the u joints. It appears that the u joints tore up the shaft ends when they snapped. Probably looking at replacing the entire axle shaft now. Any ideas on a good aftermarket drive? The other side looks like the units have play in them and I will only need the u joints for them. What u joints will work for the other side besides the kubota replacements?
Welcome to the forum. Have you looked yet at the replacements thread ( new rear u joints needed again) I started on my RTV 900? I will try to bump it.
edit: here it is. http://www.nettractortalk.com/forums/showthread.php?t=13788&highlight=rear+ujoints+needed .. I took more pictures on the most recent replacement (on the 2011 RTV 900) towards the end of the posts. The earliest information I posted on the first time I did it ( on my '05) had less pictures. There is a link on some aftermarket shafts/joints in that thread towards the end but I have never tried them. bordercollie
