ROPS lighting
Mith
Anyone added lights onto their ROPS?
I'm wondering the best way to add them so that they wont get torn off the first tree I go under? Seems some mesh over them might do the truck?
Anyone got pics?
Thanks
Here you go.
Pre-drilled angle iron and some square u-bolts. Cheap lights from Harbor Freight and Napa and a three position switch.
PB, I saw this and never wrote a reply.
Anyway, looks good. Would you share the details of your wiring, did you use a relay, or just wire them stright through the switch, and where dod you tap into the power? Did you go onto the battery, or off the alternator?
Thanks
I dont think that my roll bar is tall enough to mount lights underneath, my only real option is to mount them on the outside of the rops, down either side. Either way, yours is a pretty clean install.
PB, I like that idea! It got me thinking,......mabe I'll put some on my new 'bota. I was mowing pasture the other day, & finished after dark. The FEL really blocked the head & working lights, & if I had not known the pasture I would have had to quit @ sundown.
