new member here i have 2 rtv 900 2004 2007 the 2007 has 378 hours and the inter ujoints is gone so i order all 4 from a ebay seller for 25 dollar each instead of 75 at the dealer. so here i go start to change them not fun could not figure out how to get the spline apart was not enough room to pull apart somy buddy got his torch out and started cutting on the ujoint cloes the the tran. all well except he cuts one of the eye almost into so i need one section not. you have to buy the whole shaft 289.00 thats just half of one side. also when i took the axle out on both side the bearing was nothing but a rust pile seals had totally failed so that 4 bearing and 4 seals so im waiting on the parts the question i have is it possible to install the axle by just sliding the splines together or do ihave to leave one of the ujoints apart closes to the tranmission side </p>
