treeeman00
Hey guys. Im wondering if anyon has any info. I have a 07 rtv 900 and the lights arent working. I checked the fuses and they are all good. I unplugged the headlights and im getting 3 volts to them. I checked the voltage to the headlight switch. There are 2 wires. A yellow and a red. Im getting 12 volts to the yellow wire. 0 to the red. I know that when I switch the switch on I should be getting 12 to both. The only way I an get the headlights to work is if I unplug both wires from the switch and cross the yellow and red. I took the switch out to check it. I hooked 12 volts up to it and when the switch is switched on I get 12 volts to both terminals and 12 to one terminal when the switch is turned off. This is not making sense to me. Ill admit im not the best at electrical. would the switch be bad?
