RTV 900 rear axles
froberts
I have a RTV 900 I am trying to replace the axles in. I have the engine and trans out of it(just rebuilt HST) and I have the rear tube out and cannot get the outer half of the axle out of the tube. Is there a secret to it or am I not doing something right?? Any help would be greatly appreciated.
Welcome to the Forum! :tiphat:
Glad you're here!
I've moved your post to the RTV Owners Group. Some of these folks should be able to answer your question.
Jim
Wonder about this helping?
I wonder if this will help? According to my manual you remove the slotted nut and draw out the rear axle then you tap the outside of the propeller shaft with a rubber hammer and remove it to the INSIDE. When you put it back together you use a pipe of the same diameter of the inner bearing and tap it in place. etc..fine adjustments can be made by tightening the slotted nut. Good Luck . Bordercollie
Thanks Bordercollie! I finally got them out. The bearings were just rusted in place. A good smack and they popped right out!! Again, Thanks for your help. I will definetley call on you in the future.
Glad to help out! I have over 3300 hrs on my RTV and just love it. I use it solely on the cattle farm and have come to depend on it every day. ...Anytime I or others can help- just ask! Might be wrong but we all try.. Have a good day. Bordercollie
