RTV 900 Rear U joints
rascal810
No I am not :beatdeadhorse5: I found a alternative to buying the K7571-91320 / K7561-01220 Rear shaft U joints from Kubota for $60 each. Took machine apart to replace leaking shaft seal and discovered that the U joint were bad. Didnt figure that local dealer had them in stock anyway so I started looking around online and found that a lot of people are using the 397 precisions but grinding down the sides of there yokes but that didnt sound like a very good idea to me so I tracked down one that fits without modification. A 1-1557DL from Autozone(about $9) will fit and the 98-703 Transtar or a 5-1503X Spicer(about $25). All you need to do to get them in there is clean the paint and buildup off of both edges and they went right in for me in the vise. The spicer ones come with the wrong clips so you have to reuse your originals but the ones from autozone come with the right clips not sure on the transtars. They do sit a little bit lower in the joint so the cap is slightly recessed inside of the yoke but that doesnt hurt anything:wink: Thanks to
bordercollie for pointing me in the right direction on the ujoints, went to local autoparts store and they found these ones that were a little bit narrower but couldnt get them fast enough so I had to go to autozone...
That's good info rascal. I'll tag it so this post will be easier to find later on. Thanks, bordercollie
