RTV 900x CV shafts and other issues
36racin
Now that the engine issues are fixed I need to move on to other issues with the 900x. Most important is a full service of the machine. Along with some other known issues....
1. Front CV shafts need replacing(pass side outside shaft has no bearing left in it...Can move shaft back and forth) So I will replace both
2. Rear shafts have torn boots on them. Easier to replace whole axle than just boots
As for CV shafts..Kubota ones are greatly expensive. $400+ each. Are there any aftermarket shafts that can be used? I use Sixity CV shafts on my ATV's with zero issues from them....And I see they have some listed for RTV's.
3. Steering cylinder has alot of side to side play(where it mounts). Steering cylinder is fine...No leakage... Is this normal
4. Upper and lower ball joints and tie rod ends....Any aftermarket suppliers?
And I'm sure I need more
Todd
