So if anyone is following this I called the dealer ordered another cable, to the tune of just under 75.00, Oh well could be worse. So I bought this RTV used with 250 hrs and it has always shifted the same in and out of 4x4 HARD like bad engagment lever would almost spring back always figured it was the nature of the beast, and as I said before dont really use 4x4 that often.I could not see anything wrong only recently felt through the rubber boot and it wiggled way to much, thus cutting boot and finding it separated as seen in pictures. I think that hard wire in the middle helped it work apart can't really tell till I get the new one. Since I have to wait a bit for the new one I decided to cut the hard wire shorter and recrimp the sleeve, much to my surprise it worked and once adjusted properly it shifts like never before. Not sure if this is common or not but if yours shifts like this one did check out that cable end.
