RTV-X hydraulic tank oil
Johnny Gunz
I just checked oil and it is low. Dealership closed now. What time of hydraulic oil can I use to top off? Any UDT or Super UDT? Thanks in advance, I'm using it tomorrow for hunting and can't wait til Monday to get Kubota brand.
I'm sure you are safe with any UDT or SUDT.
In a pinch, Google search the specs for UDT/SUDT, then buy any type that is compatible, it will get you by in a pinch.
On the other hand, if the machine is functioning properly and it's not terribly low, I'd run it. Then buy the correct fluid next week.
Thanks Richard. It's running fine. I think it will get me 2 miles to my deer stand. Would rather wait and buy Bota OEM fluids Monday. Thanks for reply.
You made the good choice and decision Johnny. These things are very touchy about the fluid specifications. If you don't know what is in it you really need to find out before you just add more. Your dealer should surely know if they did the maintenance......Super SUDII is the premium have no problems stuff.............Wonder what happened that you are low???.......The worst that will happen is that you will loose power to the wheels; but you are not gonna burn anything up or ruin something........Good luck....Dennis
If you don't wanna drain/change, just make sure you add fluid within the required specs which are easy to determine. Happy Hunting???
Thanks guys. I topped it off yesterday with Kubota SUDT and it was right at 2 quarts low. I had never checked tank under passenger seat until this this weekend. I had always just checked case located under bed. May just be in my head, but it feels like i have a slightly harder launch since topping off.
