rtv900 no electric power
ford40
Hi new here stumped
I hope someone can help me I turn the key and the lights in the dash light turn to glow plugs and they all out battery is good terminals are clean the 50 amp fuse is corroded under where the wires connect do they make a replacement socket for that?
put the lever in the forward most locked position. that is the float position and you can lift the bed by hand and use the lock to hold it open.
Disconnect battery when working on it- just in case a tool slips. I had a block go out on my JD332 and new terminals solved my problem also. I invested in a good set of crimpers a few years ago and now am fixed for life or until they get misplaced. ;) collie
