RTV900 slips out of M
dtreid
New to me Kubota RTV900
If I hold the gearshift lever it will run in M gear, but as soon as I remove the pressure it slips into neutral.
Any suggestions? Hopefully ones that don't involve removing the tranny.
probably just needs adjusted. could be a bent shift fork a common problem. both easy to fix without removing the transmission.
i would disconnect the shift mechanism and manually shift it into M. then i would start it and drive it to see if it stays in gear. if it slips out then i would look into the shift fork. if it stays then i would adjust the linkage.
I just can’t get the H-M shift for to slide back far enough....bent shift fork maybe?
How do I bend it back without pulling the tranny?
i doubt you can bend it back most break but you can try. also could be the detent . the forks pull stright out from the top alonf with the shift assy. i think
Did you take a look at the video and the guy popping it back in place? I never had to do that procedure but liked the video. Good luck. collie
It just seems like it's binding so that it can't slide back the last 1/4". I've used my borescope and can't see it hitting on anything....not sure what the deal is.
just go ahead and pull the shift fork assy and you will be able to identify if the problem is in the gears or the shift assy. you are only a few bolts away anyway.
I don’t want to remove the tranny if possible. I can’t remove the shift fork unless I do. Correct?
wait a minute let me look
the shift forks slide on those polished rods. can you slide the rods to the front or rear of the transmission and lift out the fork?
the fork is held on to the rod with a roll pin or pin. can you remove the pin and slide the shaft to the rear while keeping the detent balls captive enough to lift out the fork?
Kubota rtv900
Kubota rtv900 just done new head gasket and torque nut to 31ftb. Dose any one no the torque settings for the rocker.
