Rtvx1100c front halogens wattage
Walnut1
I ordered a Nilight light bar for the front of my new rtv, do I need to use the power supply cable, or will the existing kubota wiring that supports the factory lights be sufficient? I can’t find the wattage of the front light option anywhere.
At 19.5 amps I would use at least 10 gauge wire (maybe 8 ga.) and would consider a relay to keep that current out of my switch.
just check the watts on your new lightbar and see if it is less than oem. if it is less or near oem it should be fine to use the existing wires. pretty sure the cab is pre wired so all you need is a switch
I ordered the harness that is made for the light, it has a switch and relay. I’m just not to comfortable running it under my headliner.
