Peter James
I have a RTV900 with the auxiliary hydraulic valve setup and the large side mounted hydraulic tank. I have an snow plow blade that I would like to adapt to this machine. I want to use the Aux hydraulic line to run through a 2 spool valve to control up/down and left/right. Also need some idea on plow mounting frame to the the machine. I have welding ,cutting equipment and do fabrication so that is not the issue. What would be helpful would be where to mount the plow fame to the machine and if I can route the Aux hydraulic flow through a second two spool valve. This is what I did on my John Deere bulldozer to provide power angling. Looking for plans/ photos.
Thanks,
Peter
Thanks,
Peter
