Are you refering to the center link that is connected to the tie rods?
The front axles have 7 positions. The tie rod should have the same number.
Okay, I'm with you now... Yea, they sure cut production cost in the 3 point area. I'm not very happy with the way mine is. I can't use the box blade to it's full potential because the rippers will eat into the rear tires.
I'm just running it as it came. I do have some sideways movement. But the rippers still hit the tires straight on.
Yea, I'm looking at an easy hitch. Think that will move everything back about 4 inches. Just have to change lower arm pins to longer ones from what I've seen for some of my attachments.
You need a Pats Easy Change Hitch.We maybe talking about two different things....
A buddy of mine with a NH has a Quick hitch something like this on his.
He has tried to use my box blade but the pins are not long enough to lock into his hitch.
Once the implement is on the arms, you take it off.
This is the type mine has, there are like mini top links.
Totally adjustable.
Yes they will, that's why they have slack in them now. Most of my implements are cat 1. I have just changed the pins to cat 2.Can you adjust those down to a cat 1 width?
