Tire wear on 1140
Loyalpoke
The inside of my right rear tire is wearing significantly more than the rest of the tire or other tires on the RTV. Any idea's?
Hi, Is the air pressure the same? If so, I'd jack it up and check the bearings and ujoints. When it's jacked up and clearing the ground, give the wheels a turn by hand and try to wiggle them. See how much of a time lag there is when you begin turning the wheel and when the ujoints engage. It will also be easy to listen for noises since the engine will be off. I hope it is a minor thing. This is how I check mine, which is the old style . What year model is yours? bordercollie
