ncjetskier
I have a MF 3645 utility tractor that will not start. When the key is off, the techometer is at zero. When you turn the key (but don't start it) the techometer jumps to 900 RPM. The dash shows the battery light and the low pressure transmission light and it reads STOP on the dash. The tractor will not turn over.
If I jump the tractor at the starter, everything is fine (no warning lights and engine starts right up).
I cannot locate the techometer sensor as it is not part of the alternator and there is not any wires going to the front of the engine. The battery is brand new and the alternator puts out 14.3 volts. I tried to reset the computer (disconnect the battery and push both buttons near the clutch pedal).
Any ideas or help would be great!!! Thanks.
