Turn signal & hazard lights
Rontuski
Hi, I have a RTV900 with a soft cab, windshield and snow plow. I just ordered and received a turn signal/hazard light kit. I have only looked at the directions at this point but have a couple of questions that maybe someone can help me with. 1) will the turn signals interefer with the cab? 2) the instructions show one switch in a horizontal pos (for the turn sigs) and the other in a vertical pos. I do not have a blank for another vertical switch. I have a headlight switch and the other is for the snowplow. What have others done in this situation? Thanks for your help in advance.</P>
</P>
Kent in Michigan</P>
Re: Turn signal &amp; hazard lights
You must have your plow switch in the hazard switch cut-out.The harness is made for the switchs to go in those two cut-outs. I would move the plow-switch.
