OK, y'all had me thinking about a multimount system as well as a capability for hoisting into the box.
I had a long day so I opened a "beverage" a little early (a few minutes ago) and while looking at the RTV, came up with a different idea.
The basic idea is to mount a rearward facing winch off the rear ROPS.
Basically, run a piece of tubular or U shaped steel horizontally from the 2 rearward vertical ROPS pieces. In the middle of that, mount a small winch. When I say small, I'm thinking of a 1500# ATV winch. This would get mounted about 2/3 of the way up the ROPS from the top of the cargo box. If you have a high-mount air intake, the horizontal steel mounting bracket would go right behind/through the back of the air intake (as there's a nice gap there).
This is high enough that you can tilt your bed (although not all the way, otherwise the winch cable would rub) pretty far and strap onto a deer or hog or whatever and drag it into the box. It's a relatively small winch but it may be enough to get you unstuck if used with a snatch block.
A 1500# winch probably costs less than the wiring and mounting brackets for doing a multi-mount setup using a single winch.
Thoughts?
Thoughts?
