TLK
I am going to use the deer hauler that goes into my 2 in receiver from my truck. I got it from harbor freight a few years back 40 maybe 60 bucks.
I will just plug that into the RTV and it is low to the ground and put my deer on it . Now with the new RTV X series you have 2 in receivers front and back so you could put it on the front also. Plus this will keep all the blood and guts out of my unit and just have the deer hauler to clean up at the end of the season.
How hard would it be to place a metal bar across the front of the bed (using the posts on the corners to support the bar or tube steel). Weld a bracket in the middle of the bar to support a small winch, wire to your system and use that. Then you could take it off after deer season.
I was thinking that if you place it in the posts (i believe that 1" square tubing would fit in the holes on the corners of the bed), you could then remove the whole system in a couple of minutes. Also if it is on the bed and you tilt the bed, your winch would tilt also. Just a thought.
My concern is that if something snagged along the way, a 2000# winch may not even bog down before something else bends or breaks. What's then the weakest point? Hate to have a bed destroyed.I was thinking that if you place it in the posts (i believe that 1" square tubing would fit in the holes on the corners of the bed), you could then remove the whole system in a couple of minutes. Also if it is on the bed and you tilt the bed, your winch would tilt also. Just a thought.
i bought a hook a rack several years ago. really like it. simple to use and install. http://www.hookarack.com/
Just carry two good sized ropes with you. When you kill a deer drag it to a tree. tie both ropes around the deer's neck and throw them over a branch hook one to the Kubota and drive away it will hoist the deer up now tie off the second rope to hold it there. then back under it and untie the rope now its in the bed and drive home. Lots of other ways to do with a snatch block but you get the idea.
King
You beat me to it. I've used that technique for more that 30 years, and there no manual effort required. The problem with pulling a full size deer into the bed is how short the bed is. Hard to not need to muscle in the back half into it. But better that the whole carcass, however. My old quad or the RTV drags 'em really easily to a tree too.
It also makes gutting them easy. Everything just falls out as you progress.
The bed winch would work fine if you hunt were there are no trees.
Bob
