Thought I would post to the board to see if there is something I am not doing right. I have an aftermarket 3-point system and added-on hydraulic ports (gives me hydro ports front and rear). Don't need the plow now that winter is over so I moved the assembly from front to rear to begin using implements for food plots, my yard, etc. The hydraulic hoses were a pain in the rear to remove from the front quick-connect fittings and even more difficult to get back in to the ports on the rear - so difficult that I gave up after a while.
They slide in like they should but the ring-latch won't spring back into place to lock the hoses in.
I learned a long time ago not to force things...is there some kind of "load" I need to take off for the fittings to go in correctly?
Thanks in advance folks!
Davooda
Davooda
