On my other machine I use in my deer management & hunting, other than my Kubota RTV, is my Honda Rubicon.
Changing the oil in Rubicon I notice my tires where cracking bad all over. These are OEM tires that came with the machine. They still had over 90-95% tread on them. Always been in dirt, mud. Never run on black-top road.
So happen to go to the Honda dealership for the oil filter.
Asked the parts man about the tires. He said they just sold a new Rubicon the day before, and the customer wanted some more aggressive tires, with new rims on them.
Ended up buying the pulled off, brand new, OEM tires and rims for 250$, no tax.
They are Maxxis. There are some on here, like bczoom ( who I repsect much ) who run Maxxis on their Kubotas. Figured they will serve me well on the Rubicon. My tires that started cracking bad was Dunlops.
Also: Since new, I've been wanting to put Amsoil (synthetic oil) in my Honda Rubicon. And so many has told me ( including dealerships, mechanics, and internet sources) , I could not use synthetic for it has a automatic transmission ( Hondamatic) and it is wet clutch.
So after doing much research. I have found that several companies, Amsoil being one, now has synthetic oil THAT WILL WORK !!! And it does perfectly and better.
They are Wet Clutch compatible. Also, oil has to be JASO MA rated. Has API service classification SG or higher, EXCEPT oils labeled as energy conserving on the circular API service label. Can not be a energy conserving oil. Amsoil states on label, on their motorcycle oil, " Wet Clutch Compatible "
Oils that can be used :
Shell Rotella T Synthetic
Amsoil Motorcycle
*** Might be others, but have not researce any further.
And seen this email form Shell:
"We recently ran the JASO MA friction test on Rotella T with Triple Protection 15W-40, Rotella T Synthetic 5W-40 (CI-4) and our soon to be introduced (within the next 2 months) Rotella T Synthetic 5W-40 CJ-4.
All three oils passed the wet clutch friction test. Rotella T Synthetic 5W-40 (CI-4) has more than 1.2% ash (JASO MA spec limit) so it can not be classified as JASO MA. However, Rotella T with Triple Protection 15W-40 and our soon to be introduced Rotella T Synthetic 5W-40 CJ-4 do meet JASO MA."
....... two guns
Amsoil Motorcycle
....... two guns
