14 HP OHV TECHUMSE
JWC3232
i have a 14hp ohv techumse had lots of blow by from breather tube i put new rings ,gaskets seals new breather in it started ran fine 15 minutes later started blowing oil out breather againe oil level is fine could my valves be out of adjustment they seem to have loosend abit any ideas guys also put new valve guides in jim
Will you be replacing the seals again when you replace the valve guides? If so that might fix it. Seals seem the most likely ...one of them might not have seated correctly ...
