1530 Service Manual
Rmarshia
I am in need of a service manual to take out the HST from my tractor. I'm down to the splitting of the tractor but it will not separate, It moves about a 1/2" and I do not want to create any damage. All of the hydraulic lines are off and the test pipes are out still it will not separate.
I'm glad to see you got the post working. :thumb:
Man that is scary stuff. I've never split a tractor. We have some guys here who have. I hope they come along here soon and give you a tip or two. Good luck and Welcome to Net Tractor Talk.
Thank you Doc I have a feeling that I will need to remove the clutch shaft. I removed the E-clip but the shaft doe not want to pull out.
If I continue on my own it will be like putting together a model plane when I have to put it back together. So many pieces.
