2006 Kubota rtv 900 won't move in any gear
I changed hydro filter nothing changed I still have no movement in any gear. How do you adjust the hvt? With diff lock on that engages properly but still no movement to drive shafts. Also in 4wd I have no movement as well. I took linkage control cover off and manually start machine. And manually switch gears but have no movement in any gear. Only shaft moving is the constant one from the flywheel. What's best way to hook a pressure test up for hydro?
I would recommend you take it to dealer
