431 remote help
araz33
First of all I have little mechanical knowledge of this tractor. What I need to know is how to set up hyd remotes on a 431 to operate an offset disk.
I think I need a spool to activate the cylinder but I am not sure where to come off the hyd system.
I noticed that the hoses for my FEL are connected on the clutch side and snake under coming up to the FEL block. Could I come off with a T before it gets to the FEL block?
Is AGCO the best place to go for the spool?
Would somebody pls help me get started. Made some calls today and it sounded like $800plus.
I found a 2 spool hyd valve 35 65 85 135 150 165 175 1080 for $175
Is it model specific because of mounting bracket and locations?
Could I use this valve?
Thanks for any help you can give me.
Hi and welcome to Net Tractor Talk. I'm glad you found us and hope someone is along soon with an answer for you.
