6320 blowing fuse!
nik6320
Hi there i own a 2003 6320 and recently i started having a problem with the second fuse in F03 column its the 10A one wich operates 4wd,pto and diff lock.. as soon as you turn the switch it blows it (tryied up to 20A) also tryied following the wires from the fuse box, the right one connects to 6 other fuses wich all have to do with ELX something but seem ok and the left disappears in the pannel.. Any ideas?
Hi Nik and welcome to Net Tractor Talk.
ELX has a relay associated with it. Don't know if that would cause your fuse to blow like that though.
The ELX relay is shown on the fuse box cover, check the feed wires for any cuts or open circuit. Hope that helps. Good luck.
Hi Doc thanks for youre time! i checked the relay but it seems fine all wires behind the fuse box seem good aswell.. think i propably have to start taking pannels of and follow the wires...
