Backhoe - digs!
Mith
Finally got enough done so that it almost looks like a backhoe. Still got a heck of a long way to go though!
Attached is a spec sheet, in mm ofcourse. Dig depth at 5'11", loading height 6'2".
I'm fairly sure the hoe is way too big for the machine. Nice excuse to get a bigger tractor :D
Also got a picture of some of the parts done so far. Alot of the parts for the swing joint are done too, and the stabilisers, just not welded together. Waiting for the hydraulics to turn up really....
Gees....... somebody's been busy in the workshop then..!!! Looks good. Is that 4"x4" Heavy gauge?
What is your plan for the stabilisers Mith? You gonna do hinged outriggers or the typical "jcb" style verical posts?
The box is 80x80. I'm going to add some flat bar to strengthen it a bit more too, particularly on the dipper.
Going for the JCB style stabilisers, so I can work up next to buildings.
Thanks. Spending a bit more quality time in the workshop today, working on the fenders and seat mount.
You have been busy Mith. Looking Good. Just what everyone needs ...and excuse to get a bigger tractor. :D I like the way your thinking. :D
Looking good Jim,
Out of curiosity, instead of mounting to the tractor, have you considered building it as a tow-behind unit?
Something like this?
BC, very briefly, but I cant really see any advantage to having it towed?
Thanks for the comments
The reasoning I came up with this as an option is:
1. Being a standalone unit, there's nothing to decouple from your tractor when you don't need it. You can then also have the backhoe doing the digging and the tractor to the side to move dirt as needed with the FEL.
2. The engine and hydraulic requirements can be built/established as needed without concern for what's available on the tractor.
3. Weight. I don't know how much this will weigh but is the tractor up for it? Will it be required to keep the FEL on for a counterweight?
4. Also related to weight but is weight/size an issue? Can you haul the tractor (with FEL) and BH at the same time to a job site? (I don't recall seeing pictures of your trailer or tow rig)
Brian
I've really been looking at different aspects. Cost, by using the engine and hydraulics on the tractor I can save about £1k (engines are expensive). I can fit the tractor is smaller places than I could a tow behind. On the weight, with the hoe attached to the tractor there probably wont be enough weight to dig that well, those tow behinds look even lighter....
I dont have any means of moving anything at the moment, but thats nothing a phonecall and a crate of beer wont fix, I know someone with a plant trailer.
i guess my main incentive for keeping it on the tractor is the cost, both to buy the parts, and for maintenance.
OK.
I was under the impression you have a bunch of engines and such from other tractors available...
Boxed in the fenders, and cut out some of the beam to fit the stabilisers in. I've started working on attaching the hoe to the tractor.
Mith, looking good. The frame appears rather close to the top of your rear wheels. When you have all the BH stuff on there will you have enough clearance for the wheels?
Dan, I'd like to keep the loader and backhoe all on this machine, but I've got the other WheelHorse for towing and such.
Doc, theres about 1" between the wheels and the fenders, and 2" between the wheels and the stabilizers. Hopefully that should be OK. I'm a little concerned that it might get jammed up with mud....
Cheers
You da expert when it comes to mud mith...lol
Its almost a shame to cover up those luverly rear ag tyres!!
:yum: Expert on mud? Only when it comes to getting stuck in it :D
With the amount them tyres cost, its a shame to use them!
Just a quick pic of the 'drill' for making holes in some of the parts.
Got the swing joint mostly done, and the boom and the dipper are drilled.
I was worried the joint would bind up, but it moves very freely.
Its coming together nicely Mith, nice work. What is the vertical pin pivoting on? Are you using bushings or bearings? Theres going to be a lot of pressure and weight on that joint when the jib and bucket are attached... that bit right there is gonna be a key component.... I'm enjoying the progression of this... thanks for posting.
PS I like yer "drill"...
q
There will be another plate on the top of that that hold the pin to stop it turning as the hoe arm swings. There are bushings in the swing bracket, one of these is on top of the beam in the top right of the picture.
I'll keep posting pics if there is interest.
:D
