Block Drain Plug G2000
scopeman
Hi All,
First time flushing a G2000, I was successful in draining the radiator from the bottom valve of it, the cock valve on the L side does not have any water coming form it, is this normal? is there anywhere here that I can find the procedures?
Thanks in advance,
K
Not sure if there would be coolant left if you drained the rad.
I'd say you are good to go and refill with new 50/50 water coolant mix.
Any coolant changes I've done, drain rad, refill and away you go.
Little bit left in cylinder block was never an issue.
